Group: DynoMotion Message: 1243 From: davidchoong@ymail.com Date: 6/3/2011
Subject: KFLOP + KANALOG For Mach3 Mill (Relay Drivers)
Hi TK,
Right now, I'm using KMotion and Mach3 to turn ON and OFF the Relay Drivers for:
152 FET Driver 0 None
153 FET Driver 1 ON/OFF by Mach3 (Spindle CCW/CW)
154 FET Driver 2 ON/OFF by Mach3 (Spindle Run/Stop)
155 FET Driver 3 ON/OFF by KMotion (Enable Spindle Min. Speed)
156 FET Driver 4 ON/OFF by KMotion (ATC Clamp)
157 FET Driver 5 ON/OFF by KMotion (Mini Air Compressor ATC)
158 FET Driver 6 ON/OFF by KMotion (Air)
159 FET Driver 7 ON/OFF by KMotion (Flood)
I would like to fully use Mach3 to control the Relay Drivers ON/OFF but I do not know how and appreciate your advice.
Thanks and regards.
David Choong
Group: DynoMotion Message: 1244 From: Tom Kerekes Date: 6/3/2011
Subject: Re: KFLOP + KANALOG For Mach3 Mill (Relay Drivers)
Hi David,
To control KFLOP bit numbers greater than 127 from Mach3, subtract 128 and specify port 2.
--- On Fri, 6/3/11, davidchoong@... <davidchoong@...> wrote:
Subject: [DynoMotion] KFLOP + KANALOG For Mach3 Mill (Relay Drivers)
Date: Friday, June 3, 2011, 6:36 PM
Hi TK,
Thanks and regards.
David Choong
Group: DynoMotion Message: 1245 From: David Choong Date: 6/3/2011
Hi TK,
That part I had done and able to control the Spindle using your "SpindleMach3DAC". Say for example that I would like to toggle the Flood on Mach3, how do I go about?
Thanks and regards.
David Choong
Group: DynoMotion Message: 1246 From: Tom Kerekes Date: 6/4/2011
Hi David,
In Mach3 under Config|Ports&Pins|Output Signals|Output #3 set as Bit 159 (Pin 31 Port 2).
Then in Spindle Setup UN-check "Disable Flood Mist Relays" and set Flood M8 Output as 3
--- On Fri, 6/3/11, David Choong <davidchoong@...> wrote:
Subject: Re: [DynoMotion] KFLOP + KANALOG For Mach3 Mill (Relay Drivers)
Date: Friday, June 3, 2011, 11:51 PM
Hi TK,
Thanks and regards.
David Choong
Group: DynoMotion Message: 1247 From: David Choong Date: 6/4/2011
Hi TK,
It working, thank for your help....
I will be working on others Relay Drivers setup.
David Choong
Sent from my iPad
On Jun 5, 2011, at 12:33 AM, Tom Kerekes <tk@...> wrote:
Hi David,
Hi TK,
Thanks and regards.
David Choong
